dcarlson's Avatar
odometer stopped
did I use up all my allocated miles? can average owner get at it to investigate or is this for seasoned mechanic? hints what to check first/where to start much appreciated..
'86 944
'86 911
07 cayman
Old 07-31-2014, 06:58 PM
Bradical's Avatar
The drive gear dry-rots and falls apart. You have to remove the gauge cluster and take out the speedo. Its relatively simple, the gears are inexpensive and there is a write-up on clarks garage
Old 07-31-2014, 09:09 PM
thekidd's Avatar
Send a message via AIM to thekidd
If your car is a 82-85.5 944 or 86-88 924S, the speedo is cable driven. Take off your front drivers side dust cap on your wheel (porsche crest cap), and see if the cable is still attached to the cotter pin. If it is, then your speedo gear has broken or slipped off some.
Old 08-01-2014, 04:46 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Note: when you take the cluster apart and get to where you need to remove the needle on the speedo, pull the needle at the hub with a slight twisting motion. Install the same way. The needle is a slip-fit and if you're careful it won't be damaged. Also, remember not to reset the mileage while the car is in motion. Have fun.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-01-2014, 06:22 AM
