-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Engine noise (http://forums.pelicanparts.com/showthread.php?t=824273)
horsman_f3 08-07-2014 05:00 AM
Engine noise
It seems like I have more exhaust noise in the engine bay, and a slight decrease in power at times(which I think is my fuel pump). But when I open my hood and have a listen, there seems to be more of an exhaust noise coming from the engine. What would be some things that would cause that??
tamathumper 08-07-2014 06:03 AM
Loose or broken exhaust header studs or flange bolts.
John_AZ 08-07-2014 07:00 AM
Cracked exhaust header 1-4.
Look up from under car where the 2 pipes join for cracks.
J_AZ
Bradical 08-07-2014 07:37 AM
The first thing I would check would be the o2 sensor, it's fairly common for them to be cross-threaded, which causes them to rattle loose over time. It sounds like a nasty header leak.
mytrplseven 08-07-2014 08:05 AM
Put a piece of Kleenex on the end of a stick and move it around the exhaust system and manifold. Look for the Kleenex to flutter in the area of a leak, while the engine is running. I saw this cool trick on Wheeler Dealers. It actually works.
horsman_f3 08-07-2014 04:41 PM
Thanks for the tips!!
Toran 08-08-2014 05:41 AM
Do let us know what your results are.
I am in learning mode :)
