Oprv
I'm rebuilding an OPRV on a car that hasn't been started in a long time. I ordered the O-rings today but would like to keep moving on my assessment of the vehicle. Basically, I want to try and start it this weekend but I wont have the O-rings. Can I install the valve without the O-rings and start the car without breaking anything?
Thanks, Hosmer |
Without the O rings, you will not build up any oil pressure. Do that for a long enough time (e.g. five seconds), and you will get to rebuild your engine.
Don't do it.
Can you put the OPRV back in with the original O rings, or are they trashed?
The old ones are nuked. I couldn't get the valve out of the block at first. The oil cooler O-rings went bad and the car was parked... for five years. I got the car for free and I have a $500 sunk cost budget before I part it out so I'm just trying to see if I can get the thing to start. I'll wait for the O-rings though, just in case I get lucky and the engines still good.
Interesting car to work on. I replaced the oil cooler O-rings last weekend and not one broken or stripped nut or bolt. I don't know why but I find the unusual... Thanks for the advice, Hosmer |
But don't speak too soon, the tiny M6 waterpump studs will come out in pieces.... unless you leave them be. |
Are you talking about the one piece OPRV? I have never seen one so I can't comment.
But I can tell you the three piece OPRV does not use O-rings. O-rings are only used on the oil cooler pipes on the 3-piece OPRV setup. At least this is the way mine went back together on an 85.5 model year. If you try to use O-rings on the three piece OPRV no telling what might happen. The plunger might get stuck in the bore. Do make sure to use an OPRV alignment tool, too. http://forums.pelicanparts.com/uploa...1413732254.jpg |
Nertz... now I'm completely stumped, and stuck. I put a green and a black o-ring on and now the thing is stuck again. I hope I don't have to remove the casing to get it out. I used the alignment tool and it moved freely. I think I have an o-ring problem and will have to do more research. Looks like I have a bevy of write-ups on the subject so that's good.
I will say the dam thing is confusing. There's supposed to be two valves, I know mine does not look like the one above but its in no way one piece. Its not three pieces either, its four. The nut, a spring, a plunger and a tube the plunger slides in. |
If you need a good OPRV, I have a few. One is an early 3-piece (17mm) and one is a 1988 late retrofit valve that opens and closes smoothly (24mm).
It looks like I have version #3 of the valves pictured in a '86 - 944 non turbo, std shift. Is that OK? From what I've read, that valve is for an '87 on.
http://forums.pelicanparts.com/uploa...1414719957.jpg Thanks for the help on this... p.s. I obviously picked the photos from this write-up (944 Foot To The Floor: How to remove and replace OPRV (Oil Pressure Relief Valve) on a Porsche 944) hope that's okay... |
#1 is the original OPVR (3 piece) for all cars up to (I think) 87.
#2 is the retrofit OPVR (1 piece) for those same cars as in #1 #3 is the OEM OPVR (1 piece) for 87+ cars. If you have an '86 block (Look at the 44.xx number stamped on it), then you need a #2. The #1 is a matched set for the plunger and the piece in the block. |
I found this near the oil fill, close to the firewall. I think its on the engine and not the bell housing. To me, it looks like M44 707 and 43H0834... So that's an '86 right? If so, I have the wrong valve...
http://forums.pelicanparts.com/uploa...1414758010.jpg |
So engine swap at some point then because date of manufacturer is 10/85 and vin says 1986... I have the right valve but purchased the wrong O-rings which explains why the thing is stuck. Live and learn I guess.
| All times are GMT -8. The time now is 12:02 PM. |
