83 944 starts and shuts off
83 944 runs in start position only. When key is released to run, it stalls. Never looses spark, the fuel pump runs until the engine stalls, 30 psi fuel pressure , replaced ign switch, speed and ref sensors. With all injectors unplugged it has 12.8 volts on the pos. side of injector connector but has 10.5 volts on the ground pulse side. Is this voltage on the pulse side normal. Please help.
