1983 944 steering wheel
steering wheel is cracked and need to remove. what are steps to remove. making sure I don't break something, clips,etc. no airbag involved
It's really simple, the horn pad pulls off exposing a large nut (21mm? Citation needed...). As per usual Clark's Garage has a write-up on it. It's a good idea to use marking paint on the shaft so you have an idea on how to center it up when you go to reinstall.
Patrick
Actually, it's 24mm...
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
Pretty sure mine was 21mm also.
Have 944, will restore
-Remove the horn pad buy pulling it straight off. Three clips hold it on.
-Unclip the wire for the horn on the back of the pad -Remove the but that holds the steering wheel in place -Use a paint marker and draw a line over the steering shaft and wheel to mark the position of the steering wheel -Wiggle the wheel top to bottom and pull towards you. The wheel should slide right off.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
