-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   How do I replace the Climate Control bulb? (http://forums.pelicanparts.com/showthread.php?t=84660)
BikeDewd 10-18-2002 09:05 PM
Hello group,
I've had my 1986 951 for about 4 months and recently the Climate Control bulb had become "intermittent". It occasionally works, but more often than not, doesn't. I took the Climate Control out of the dash, thinking that the bulb would just plug in the back, but -- wrong!!! OK, so then I figured it was behind the black plastic cover on the back, but -- wrong!!!Leave it to Porsche to hide it somewhere inside with no way to replace it.
Am I missing something here?? Do I have to repalce the entire Climate Control for the bulb to work? Inquiring minds -- and pocketbooks -- want to know!!
Thanks for any help....
Jay
SoCal Driver 10-18-2002 09:20 PM
Geesh. You just had to ask about this. Just read a fairly extensive artical about the later 944 dash lighting and replacing it with diodes. Now where was it????
BikeDewd 10-18-2002 09:32 PM
Yep. I think I remember reading that same article....didn't think much of it at the time because it was working perfectly......
Anyone???
Ross T 10-19-2002 12:33 AM
Bikedewd, I think you can just pull off the knob, either the fan speed or temperature and push the bulb in a little bit, and twist. It should pop right out.
BikeDewd 10-24-2002 06:41 AM
Thanks Ross,
It definitely is a loose bulb. I can push on the temperature control knob and the light will come on, but when I let off it goes out. I tried pulling on the knob, but it doesn't seem to want to come off....don't want to break anything -- do I just need to give it more muscle???
Thanks,
-jay
Ross T 10-24-2002 09:48 AM
I was mistaken. You do NOT have to twist the bulb. Simply pull it straight out. I used needle nose pliers.
There are two metal contacts on the bulb that are folded aginst the glass at the base of the bulb. bend these out just a bit to ensure they touch the contacts in the unit itself. This should fix your problem. You say the bulb comes on when you push on the knob, so all is working fine but there is a poor electrical contact somewhere. Let me know how this turn out.
Ross T
944S/968 conversion
Ross T 10-24-2002 09:52 AM
.. you may want to clean the metal contacts on the bulb a little with fine sand paper or steel wool. maybe you can just gently srape the contacts with something metal, or a fingernail file.
