924S no start
Hi
I'm hoping someone can point me in the right direction. I replaced my fuel pump (twice) last summer, drove it up until cold weather started, so I have had it put up until 2 days ago. It started and ran fine, until today. When I came out to leave work, it started, ran fine for 20 seconds or so, then died. Although it would turn over it wouldn't start. I checked the fuel pump fuse, checked (listened for the "whirr" of the pump) and also checked the fuel rail for pressurization...nothing. An hour later, after I grabbed my meter and tools to check for voltage, I decided to try starting it and it fired right up w/ no issues and I was able to drive it home, where I've started it several times since. Anyone have ideas I might try to find this? Thanks |
Proprietoristicly Refined
Did you replace the DME/fuel pump relay?
DME Relay Information and Testing Ballysdad did a "No Start Checklist" http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/484996-let-start-no-start-checklist.html Or just review ideas on Clarks-GArage: Clark's Garage Home Page When you tried to crank the engine, did the tach needle bounce 1/16th of an inch ? If not, could be the reference sensors. Is the battery at absolute full charge after the winter break? If the battery was weak it may have harmed the delicate electronics. GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) Last edited by John_AZ; 01-18-2015 at 05:05 AM.. |
Thanks for the info. Mine appears to have a 5-pin fuel pump relay. I mention this because the 944's have a 6-pin DME relay I guess. I'm going to make a jumper set and have it ready for my next "episode"
Toofah King Bad
Or put in a new relay.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
winter-hater club member
intermittent bad connection at the reference senders plugs, perhaps.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
I'm not one to throw parts at a project and see if they stick. I am puzzled as to why the tech info on the DME relay indicates I should have one since its a 1987 model and the EARLIER models have a fuel pump relay
![]() I think this is it from the manual and the wiring numbers |
they both have a DME relay. the one you have pictured is not it. but i could be wrong.
You are correct, Sir...and I am humbly mistaken
I think the numbers on the relay had me confused..At any rate, relay # 2 on the block is listed as fuel pump(according to the owners manual) and after I pulled it, it has DME relay printed on it The numbers 30,85,85b 86 and 87 are in parentheses Thanks Ill make my jumper for this socket |
i remember having the same confusion with my '83 944. i am not sure where the relays are located on the 924S, in the '83 they were stuffed under the dash and it ridiculously hard to get them out and/or see what they were.
