Fuel Mixture Q's
1983 944 N/A
I've searched through past posts and I found two different values listed for the voltage that the O2 sensor is supposed to put out when the engine is running correctly. I've found .9V and I've also found .45V. Currently, mine is running at .83V when it is warm and it seems to be a bit rich to me. So, I'm guessing the .45V is more correct? Also, when at idle, what should the fuel consumption gauge be reading? Oh yeah, keep in mind I'm in Denver.
Found this:
Ox sensor: In the 85.5 DME testing procedures with engine at idle and warmed up is from 0.1 v to 1.0 v. with a digital meter. Both testing procedures insist that you use a CO2 tester for accuracy. High altitude switch: For early pre 85.5 944's terminal 28 at the DME is switched to ground above 1000 meters (3,200 ft.) This switch is connected to terminal 30 on post 85.5's while DME terminal 28 goes directly to ground. One of those differences between the early and later 944 DME's. DME 30 on the early 944 DME's looks like it doesn't connect to anything.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
So, there isn't really a specific reading I should be getting off of the O2 sensor? Anything between .1V and 1V is OK?
What about the fuel consumption meter? What is a general reading I should be getting on that when the car is at idle? Like I said, based on strong fumes, it seems that the car is running rich, but I'd like to get a little more accurate than going off just fumes. I'm kind of starting from scratch (as far as tuning the fuel air mixture goes on this car) because this is a (new) used engine and the PO had already messed with the AFM. I'd like to get it close before I bring it to a place with serious testing equiptment so that they don't have to "fiddle" with it too much. |
Where do you smell the "strong fumes"?
The voltage values are all I could find quickly in the factory manuals. This does not mean there is a more precise read out chart somewhere. The fuel consumption gauge has two scales. You use the gallons per hour for all gears except 5th where the gallons per mile is calibrated to -- with stock diameter tires. This gauge uses the info from the tach and the speedo. Not that accurate as the post 85.5's just have a "Shift Now Idiot" light. Still it's impressive when you are cruising at 85 mph and tell the passenger were are now getting over 35 miles per gallon! What did the PO do with the AFS? Porsche calls this the Air Flow Sensor. OT--- It's "take it to" not "bring it to". You take it there and bring it here. Or bring it with you if you are coming to me(here); take it with you if you are going to work (there). That double 't' rule. Don't get me started on "got"!
The fumes are coming from the tail pipe. It doesn't smell like anything specific, like gas or anything... it's just a really strong exhaust smell. It might just be some bad fuel as the car has been sitting for a while now without being really taken out for a good drive.
I don't know what the PO did with the AFSensor (as you call it.) The black cover was broken loose when I got the car, so I'm not sure what type of adjustments were made in there. I wish I knew. I guess without decent equipment it's difficult for me to adjust the mixture so I'll just have to TAKE it somewhere. Quote:
Only on a Porsche board... well, probably on the english professors united board as well. Don't get me started on "anyways." |
It's not ME that calls it an AFS it's what Porsche calls it.
If the cover was loose then you can check the resistance values at the back of the connector. The early 944's use 8 volts at the sensor to "power" the resistor. Think there was a previous thread where I posted the voltage values. Was on the "other" board. Here: ---------------------------------------------------------------------- Pull the rubber weather boot off of the back of the plug to expose the wiring and pins. Put the connector back on the AFS and turn the key on. Pin numbers as you stand in front of the car and look down at the four wires pin 22 in on the left (passenger side) pin 7 is next (left of center), pin 9 is the third from the left and pin 6 is the last on the right next to the empty socket. I just checked mine. For the early models: From pin 9 to ground should be => 8 volts. From pin 7 to ground should be 0.15 to 0.25 volts. Leave volt meter on pin 7 and push the flap full open. Should be => 8 volts. For the post 85.5's: From pin 9 to ground should be about 4.6 volts. From pin 7 to ground should be 0.15 to 0.25 volts. Leave volt meter on pin 7 and push the flap full open. Should be about 4.6 volts. I've resurrected a few AFS's by pulling off the black cover and relocating the two wipers on the carbon coated ceramic resistor base. Moved them radially from center. Not fore and aft. Just a little. Cleaned the resistor and wipers with electronics "tuner" cleaner. Seal the black cover with silicone. Don't let the silicone drip into the resistor cavity. Reference Porsche 83 and 85 DME Testing Procedures. ------------------------------------------------------------------------- I'll add that when moving the flap the resistance should change somewhat smoothly.
Re: Fuel Mixture Q's
Re: Re: Fuel Mixture Q's
Thanks SoCal Driver, I'll be sure to check those values and make sure everything in the AFS is funtioning correctly.
Or???? What do you guys think? |
Has the car always been in Denver? If so and your running rich you probably have dry rot on the intake boot.
You may also have dry rot on the vacuum lines. My 85.5 and my 87 both were Colorado cars and all of the lines and boots were rotting. For anyone who has never been to Denver before, its vary rare that we ever see any measureable humidity, its extremely dry.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Hey scott I just emailed you before you posted.
Yeah, I went over the intake boot and it's definately dry rotting. But, it doesn't appear to have cracked all the way through yet. I have also gone through all of the hoses and made sure they were ok... they are now. |
Re: Re: Re: Fuel Mixture Q's
Re: Re: Re: Re: Fuel Mixture Q's
I can't believe Mr. F.R. Wilk didn't get involved in this thread. He must be on a tequilla drunk.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Yo Shepper, I couldn't stay away from this one, I tried. I see that the board already has given you good advice. Porsche does reccomend adjusting the CO with the O2 disconnected, and the engine warm. I believe the CO adjustment screw is on the vane airflow sensor. It usually has a plug in it which needs to be removed although I'll bet yours is already gone. The O2 sensor is designed to run between .1-.9mV (millivolts). Closer to .1mV is leaner, while .9mV is the rich end of the scale. The O2 when warm must fluctuate repeatedly and smoothly from lean to rich. The DME is programmed to run at an optimal stoichiometric value of 14.7:1, or lambda. 14.7:1 refers to a mixture of 14.7 parts air to 1 part fuel. 13:1 would be a rich mix, while 16:1 would be a lean mix. Anyway, this value approximates to a voltage reading of .45 or 450mV, which is the best compromise between performance and emissions. Warm up the O2 and whatch the voltage, typically a bad O2 will "stick" or stay at a particular reading for loger than .75 seconds. Also, if your O2 averages around .83mV, this would indicate a rich mix and can be confirmed with a for or five gas analyzer (read: expensive). If your CO readings are excessive, this will verify the rich mixture and tell you that your O2 is healthy. Your CO values can be found on the VECI (Vehicle Emission Control Information) label under the hood. Just make sure you take the readings before the catalytic converter, there is a test pipe which comes up the back of the engine. It is usually capped off or missing entirely. Good Luck.
Even though I drove a GT2, I still love my 944. |
Excellent info turbohead7, thank you.
I haven't had a chance to mess with it yet since I posted last, but I'm going to work on it a lot this weekend. Your post raises one more question. You say that the reading from the O2 sensor should fluctuate around an average. Do you know the approximate range around that value that I should be looking for? |
