Power steering and devine intervention
can anyone explain why my powersteering has suddenly stopped leaking?..Car handles beautifull, and yes the pump ios working also. Maybe the seals have just ....er.. resealed?.. Todwic?.. anyinfo from you is well worth a look.. eh?...
may the schwartz be wit chew, Frank B ps.. rent the movie strange brew.. it's hockey seson. |
The reservoir is empty.
it's full Socal, weird huh?.. radiator has a small leak, need a new one.. dang!.. but the P.S. is workin just fine now, even when I crank all the way left or right....
thanks Socal,........ |
Most cooling leaks around the radiator are loose or cracked hoses. Every so often the plastic sides crack or start leaking at the seal. Then there are a couple of plastic fittings that screw into the plastic that leak. These you have to be really careful with not to over tighten. Lots of teflon tape. Back to the hoses. If you have "mud" in the overflow tank there is oil in the coolant. This oil can ruin the hoses. I've also seen the hose fitting on top of the engine deteriorate because of the absence of antifreeze. Doesn't leave much for the hose to clamp to. |
yeah, plastic at the bottom has a teency weency crack, but it's not bad.....thanks SoCal. Why does this car feel like it's more comfortable at 60-100mph than 10-35 mph..?.. any help?......
A blend of the best technology available in the early 80's to make a touring coupe. I think of it as a modern steel rail coaster that has a highly flexible track! |
hehehe...good point :p
80mph is my car's happy spot, I don't question providence, I just smack 'er on the arse and ride. |
Yeah I agree with 80mph..she just seems so happy there...oh bliss..glorious bliss...then again i ahve to get up in three hours and drive the CRX into brooklyn...GReat :( -chris
3days of cars and fun, 2weeks of garbage...dohhhhh |
I have just hit the 944 MARK !!!!!!!!!!!
Two pats one the ole back... Registered: May 2001 Location: @ The PALSY FACTORY in Long Island, NY Posts: 944 |
Exorcized/banished to a pit full of rabid wombats the evil random engine leak gremlins AFJuvat |
| All times are GMT -8. The time now is 08:42 PM. |
