Exclamation 944 transmission bearing NLA please help
Hello, I am overhauling my early 944 transmission. However, the main shaft needle bearing at the front of the case is No Longer Available, even through the dealership they cannot find it. I've tried the internet and bearing distributors and dealerships and parts stores, this bearing is non existent. the bearing is damaged and needs to be replaced, has anyone else run into this issue or know where I can find one? Its an FAG bearing number 310-4088 [img] Thanks in advance
Old 04-16-2015, 11:09 AM
Proprietoristicly Refined
John_AZ's Avatar
Contact member Kevin Gross
Kevin
Catellus Engineering
catelluseng@gmail.com
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-16-2015, 11:23 AM
kevingross's Avatar
This part is indeed no longer available, at least at the present, as part number 999-201-476-00, 083-311-123, or 083-311-123-TPP. I can provide a good used one -- they are fairly indestructible and rarely need replacement unless something unusual has happened. PM me or email to catelluseng@gmail.com for a good used part.
I did find someone able to supply it as a new part in the bearing aftermarket, for $125 each. Contact for a new part would be:
SONIC BEARINGS
36-947 Cook Street, Suite 104
Palm Desert, CA 92211
844.849.2933
sheila@sonicbearings.com
www.sonicbearings.com
Kevin
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 04-17-2015, 12:27 PM
you could try what i did for power steering pinion bearing, go to a bearing distributor have it speced out and see if any other brand has a bearing of the same dimensions available. and then check amazon to see if they have it.
Old 04-17-2015, 02:36 PM
Tags
944 , bearings , transmission
