-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Help with power steering rack install (http://forums.pelicanparts.com/showthread.php?t=860746)
regnihe 04-15-2015 07:26 AM
Sanity check. There are two connections on the rack. Return line and pressure line.
Looking at the back of the tower casing, which line goes in the top and which goes in the bottom? Thank you.
Techno Duck 04-15-2015 07:33 AM
Bottom fitting is the high pressure. Top fitting is the return.
regnihe 04-15-2015 07:37 AM
Thank you. Any idea what would happen if I reversed them?
