gt350mike's Avatar
Changing Instrument Clusters ???
We bought an 87 944 n/a that needs the instrument cluster replaced. Any cluster I get will need to have the mileage change to the orginal miles but is this possible w/o damaging the speedo? If possible, how do I do this? :confused:
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-03-2002, 02:48 PM
SoCal Driver's Avatar
Why does the instrument cluster need replaced?
Yes you can carefully open up the speedo and reset the milage.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-03-2002, 04:01 PM
Here's a blow up.
Page 90-10 in the factory manuals.
Old 11-03-2002, 04:06 PM
gt350mike's Avatar
The PO (not the POS as previously posted....oops) tried to replace the factory gauges faceplate with a white faceplate and trashed the speedo in the process.
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-03-2002, 04:56 PM
Never could figure out why some owners just have to have the trashy looking white face gauges.
Old 11-03-2002, 05:11 PM
gt350mike's Avatar
I was proud when my son said that "If it came from the factory black, then he wanted to leave it black". I admite that there are a few cars that look good w/ white gauges, but not tour 944!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-03-2002, 06:06 PM
AFJuvat's Avatar
Well, to quote an old wise german guy....
"Don't f*ck with perfection"
"and thats all I've got to say about that."
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-03-2002, 07:04 PM
AFJuvat's Avatar
If you have a series 2 944 (85.5+) there is no way to set the odometer.
you should just make an annotation of the current mileage before you replace the current one.
WARNING: Replacing the entire instrument cluster will cost in excess of $1500. Determine what the problem is and order accordingly. If you need part numbers, we can provide them for you.
AFJuvat
Old 11-03-2002, 07:08 PM
gt350mike's Avatar
The speedo unit (referring to So Cal's pic, the unit is #9) needs to be replaced. I can either get one from a salvage yard or buy one new.
AFJuvat, I agree with you (or your buddy)!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-03-2002, 07:20 PM
C5Driver951's Avatar
It's really fairly simple to replace the speedometer in these cars.
Any 85.5 or later will work, as they all use the same gauges. If you must replace the gauge, buy a used cluster. Used instrument clusters are sold regularly on E-bay for around $100. Of course people parting out cars will have them as well.
Joel Wahlsten
89 951
Old 11-03-2002, 07:45 PM
I have one for an automatic. Has the GPM gauge.
Old 11-03-2002, 08:39 PM
Sternn's Avatar
I know the 951 has the MPG on the tach in the cluster, the question is if you replace a 944 N/A with a 951 cluster,
A. will it work?
B. will the MPG gauge work?
Curious.
- Sternn
- 944S - Project Car
- Web Master & Used Part Guru From
- www.stuttgartparthaus.com
Old 11-04-2002, 06:41 AM
gt350mike's Avatar
Another stupid question....What is a MPG gauge? Is it "miles per gallon"?
If so, who would give a s... that your mileage is in a Porsche?
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-04-2002, 06:50 AM
Scott R's Avatar
It was a stupid federal emissions thing on some imports. Same as that stupid "upshift light."
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-04-2002, 07:00 AM
gt350mike's Avatar
The upshift light can be useful, it just needs to be programed to come on just before redline!!!
Then we can call it a "Shift" light!!!!!!!!!!!!!!!!!!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 11-04-2002, 07:28 AM
Gallons Per Mile and with a sub scale Gallons Per Hour (really more useful). The GPM is only useful in fifth gear.
Some years/models have them. Some don't and use the "Shift NOW Idiot" light.
Yes the sub gauges innards are more accessible with the post 85.5 instruments than the canned and sealed early model instruments.
Old 11-04-2002, 10:50 AM
