944 Vs. 944S Tranny
Is there any difference between a 944 N/A and 944S tranny?
-S
------------------------------------------------ - Sternn - 944S - Project Car - - Web Master & Used Part Guru From - www.stuttgartparthaus.com ------------------------------------------------ |
Mein Gott!
I remember reading somewhere that the 944S had "larger, meatier ring & pinion gears, which was the achilles heel of the original 944 transmission". Also, that it has the same gearing of the 951. Never read or heard anything more in detail about it, though. Anyone?
The 944S does have a stronger ring and pinion. It also has gearing that is closer. In the 944S 5th@3000rpm's= 62 MPH.
The turbo's tach would be somewhere around 2700 rpm's at the same speed. |
