suck my tail pipe
I have an intermittent noise coming from the right rear whell area.. sort of a clunk when I accelerate. I've only heard it once for .. maybe 5 minutes, then it stopped. Was it a C.V. joint?.. or should I smoke a joint and ignore it?.. all suggestions are welcome.
Frank B
My car is naughty |
I have pretty much the same thing going on. It will clunk under acceleration sometimes, and then sometimes not. I am pretty sure that it is the CV joints, but I am just waiting to fix then until after I fix my engine.
85.5 Red 944 Http://members.rennlist.com/afx |
Could be the CV joints.
They look like this when they get "well used":
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
suck my tail pipe
OH!.. mhmmm.. I see..
well, could it be my rear axle?.. maybe?.. or a lack of grease somewhere in the rear?.... Frank B
My car is naughty |
There are four of these CV joints. One at each end of the two axles. They have billow covers over then. They are greased with molybdenum. They are held in place with six bolts. They should be removed, checked and re greased at 30,000 mile intervals.
If not maintained they have a tendency to clatter going around corners. Most likely yours have never been removed and inspected. The transmission/differential holds about two quarts of lube. If it's low the differential starts to howl. Two CV joints on one axle about $180. One rebuilt transmission $1,200. Preventive maintenance, priceless.
Re: C.V. Joint Noise. intermittent
I am hard pressed to see where you can go wrong with pursuiing both routes here. Wait...I only see one plan of action there...go rasta till da babylon, him come callin. You need a cheese head (8 mm I think) socket to yank those 12 or so bolts that hold the c.v. joints on. Pull em one side at a time (try not to let them dangle, they can come apart on you, and they only go tegether one way, though you'll swear you almost have it with 7 other combinations) Look at em. Socal gave you a cleaned up pic, if any look like that, order new ones. If they have plenty of grease, no catches or worn places evident to your visual inspection, slap a hand full on good c.v. joint grease in it and bolt it back on. They recoment you use brand new bolts when you put it back together, but at a $1.30 a bolt X 12 X 2 X 2=they can kiss my ass. I've used the old bolts with no ill effects for the better part of a year. Repeat with the other 3 joints. Kragen (a nat'l chain discount part store) carried the right c.v. joints for my '84, and I have a sneaking suspission that VW joints will fit. Kragen c.v. was @ $50 or so, Axle not included. save the circlip. Save the old parts, the outer hub ring makes a dandy paper weight. Light joint, enjoy your day.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Re: Re: C.V. Joint Noise. intermittent
Have to put heavy surgical tubing on it.
