Car died when i turned the ac on please help.wont restart
Started the car up this morning second day of getting it to run good now and turned the ac on and the car just died right away no spit no sputter just died and now it crsnks has spark and has fuel pressure. Wont even try to start please help was hoping to get plates on the car today and make it legal thanks
1. Check the NEG ground on the engine block.
2. Is the battery fully charged? 3. Check the fuse block for a blown fuse. 4. Does the tach needle bounce 1/16th of an inch when you crank? 5. Change the DME/Fuel pump relay. URO brand cheap and bad> 6. Check the connection to the AFM. 7. Did the AC compressor B+ short to the frame? (12 inch wire from the compressor to the frame connection) and... J_AZ |
Is the compressor locked up?
| All times are GMT -8. The time now is 07:23 PM. |
