-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   A/c will not engage (http://forums.pelicanparts.com/showthread.php?t=885863)
dondarnell 10-05-2015 08:32 PM
A/c will not engage
Was working fine. Stopped working. If I push a/c button it won't stay on. Swapped out relay, checked fuses. Where to look next?
John_AZ 10-05-2015 09:20 PM
If low on Freon the "low pressure switch" near the receiver dryer will not let the compressor engage,
You can jump the low pressure switch with a paper clip and if the compressor engages you found the problem.
Maybe??
J_AZ
Arizona_928 10-06-2015 12:42 AM
Radiator fans function?
