| mcavour |
11-28-2002 08:36 AM |
HELP!!! 2.7l Cooling hose connection
I have an '89 n/a with the 2.7l engine. I am in the last stage of replacing t-belt, balance shaft belt, accessory belts, oil cooler seal, and etc... The water pump that I took out only had one connection, to the lower radiator hose. Due to this connection the hose coming from the expansion bottle was connected to a small aftermarket hose and into the radiator just above the lower hose outlet. I got a new pump that has a spot to hook up the hose from the bottle (or so I think...) I currently have a cap on that spot. If I make that connection I will be left with a spot on the radiator (which I could place a cap on) My question is how is this supposed to be connected??? :confused: :eek:
