We're looking to replace the instrument panel in my son's 87 N/A. I found one on ebay that came out of an S model, but I'm not sure if it would work in his car. Will it???
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
To the best of my knowledge yes it will - they should be the same.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
The question is, will a 951 work in a 944 or 944S? The only difference is the little MPG meter. Does that have its own special sender or is it merely a hookup on the DME?
------------------------------------------------ - Sternn - 944S - Project Car - - Web Master & Used Part Guru From - www.stuttgartparthaus.com ------------------------------------------------ |
As Far as I can tell the MPG/GPH gauge does hook up to the DME and the speedometer. The pin numbers between the "S" and the 944 DME's are different but you would think this is the same signal for both -- the injector delivery rate.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
