daveimme's Avatar
Send a message via Yahoo to daveimme
Found the fuel level sending unit....now what?
I did find the unit under the mat and a square insulating mat right over the sending unit. I see 3 conectors and about 6 or so hex heads....do I remove the hex screws to get the unit out? or do I just unhook the connectors and twist it out?
Once done....What am I looking for and how do I know if it's good or not?
83 944 N/A 5 sp. (mine)
90 Acura Integra auto (sons)
2000 Honda Odyssey EX auto (wife)
83 Suzuki LT 125 (4 wheeler) (wife)
92 Honda XR 80 (son)
97 Honda CR 125R (son)
98 Honda CR250R (MINE)
2000 Kawasaki KX 65 (son)
2003 Honda XR 50 (Son and daughter)
Old 11-30-2002, 07:56 AM
AFJuvat's Avatar
Yep, you have to remove the bolts (should be 5 if memory serves)
it should lift right out after that, lift it slowly and allow the gasoline in it to run back into the tank.
Check the condition of the seasling rings under the bolts, and the O-ring on the bottom of the sender.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-30-2002, 08:01 AM
