1986 Porsche wheel size
I have a 1986 Porsche - base model. I am considering purchasing new rims. Can anyone tell me whether 16x8 rims would work? Thanks
Toofah King Bad
Call Dave at Wheelenhancement.com
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Sure 16x8" will work with 23.3mm offset.
You can also use the late-offset 52.3mm wheels, but will need to add a spacer. There's an error in the 944FAQ in regards to the specs on stock 86 wheels, so don't use that; it'll be confusing. |
yes - upgraded mine and went to some wider tires as well.
![]() Package 1: 2-7x16 Replica Alloys With 205/55-16 Fuzion ZRi Ultra High Performance Z-Rated Tires. 2-8x16 Replica Alloys With 225/50-16 Fuzion ZRi Ultra High Performance Z-Rated Tires. automotion
'86 944 '86 911 07 cayman |
Yes, but only if the offset is right.
Thanks. Dcarlson if you do not mind sharing where did you buy the replica fuchs? Thanks
probably these. http://www.***************/catalogsearch/result/index/?Brand=Brand%3AEuromeister&ea_a=Brand%3AEuromeister&ea_bc=&ea_c=&ea_path=-euromeister&q=euromeister
quite high on my want list except freight would be a killer.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 11-21-2015 at 07:31 PM.. |
Page does not come up
try this
http://www.***************/euromeister-alloy-replica-wheel-7x17-et-23-3-for-porsche.html do a search on pelican forums on 'euromeister' to read feedback on quality and service.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
http://www.***************/replica-alloy-tire-and-wheel-package-package-1-for-porsche.html.... whenever they are again available
http://www.***************/euromeister-alloy-replica-wheel-8x16-et10-6-for-porsche.html
http://www.automotion .com/euromeister-alloy-replica-wheel-8x16-et10-6-for-porsche.html i think a mod or admin has swear banned their url!!
that's understandable - If our host had offered them I probably would have ordered them here.
What's the weight on these replica wheels? I take it they're not 1-piece forgings like the originals?
