knock sensor check?
Guys is there a way to check the operation of the knock sensor? The reason I ask is because I am currently working on the top of the engine replacing a bunch of hoses, vacuum lines, installing venturi delete, and checking sensors for their operation as well as cleaning them up. I am also going directly to a manual boost controller setup avoiding the cycling valve so I assume that the knock sensor is very important to me at this point.
Look forward to hearing Thanks Paul |
According to the factory manual, the check for the knock sensor is to have the engine running, a timing light showing the ignition timing, tap the knock sensor with a hammer and observe that the timing is retarded a few degrees with the tap.
May I ask which models have a knock sensor? Just the turbo's or the n/a's too?
According to the PET, the turbo models have one each and the 16 valve motors (944S, 944S2 and 968) have two each. |
| All times are GMT -8. The time now is 12:53 AM. |
