Low idle until warm, then stumbles
I have got my 951 running, but when I cold start her, she will idle at 400-500, until she warms up. But when she is warm, and i rev the car when warm, she will dip back down to 400-500 and stay there, until it warms up. She will also do this on a warm start, right after she warms up and i shut her off, then start her right back up. She has all new vacuum lines, but maybe one or two isn't tight enough? I don't hear a vacuum leak, but thats not a true test, I know.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
Not sure if they are the same as the non turbo but you're idle control valve for the ca maybe stuck open. ( aux air valve)
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Coolant sensor, O2 sensor and AFM are important when you get warmed up and into closed-loop also.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
944 addict
I'd suggest starting with the DME temp sensor under the front of the intake manifold (blue connector) It could also be the connector is loose or not making connection. Get a copy of the DME connector pin assignments and see if the readings from the sensor are reaching the connector.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
