todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Oi!
I think I've blown my head gasket. #2 cylinder has little compression, and I have exhaust fumes in my oil, so much so that my dipstick keeps popping out. When I pull the cam cover plugs I got lots of exhaust fumes comming out of there. Poured a little gear oil into the cyl. and compression value went almost to normal. I thought the rings may have callapsed, but all the other cyl. are normal. Thoughts?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-05-2002, 04:30 PM
AFJuvat's Avatar
Unhappy ARRRGH
Dipstick popping means pressure inside the crankcase is has gone up to unacceptable levels - the only thing that can raise crankcase pressure is combustion gasses getting past the rings
It is possible that a head gasket could be the culprit. However, you should see bad compression across two cylinders rather than just one.
By putting gear oil in the cylinder, you are effectively "sealing" the rings, allowing compression to rise.
Sorry....
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-05-2002, 07:42 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
FUNGOOL!!,
I'd take a poke at cracked piston, or bad piston ring, or possibly you were high and drove without oil maybe ?.. hehee..
not the head gasket though.. you'd see a deteriating level of compression along all of the pistons..
I've had this happen to me before in my (gorgeous) 70 el Camino!!
I blew (bent) a rod and F'd up #1 piston, it knocked like hell and the dipstick never sat right again.. so, I sold her....
good luck
Frank B
My car is naughty
Old 12-05-2002, 07:51 PM
suck my tail pipe
Frank B's Avatar
did I just type deteriating?.. Fughedaboutit I meant to say gradually decreasing compression.
Yeah tha's what I meant to say..
Frank B
My car is naughty
Old 12-05-2002, 07:54 PM
todwic's Avatar
That's what I was afeared of. Someone grab a bugle, it's time to blow taps.I'm gonna take the head off tomorrow, find out exactly how bad I killed her.
'86 951
Old 12-05-2002, 09:00 PM
Scott R's Avatar
Why worrie? Used blocks are cheap, you seem to be up to just about any task, it's not that bad to change.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-06-2002, 07:08 AM
SoCal Driver's Avatar
Locally I know of two possibly three low mile engines for around $500. Great to be in the west where %50 of Porsches production winds up.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-06-2002, 09:31 AM
