callmethewander's Avatar
A/C clutch always engaged?
My compressor pulleys clutch remains constantly engaged, wether or not I have the A/C switched on. I know that it is supposed to cycle on and off when running the a/c but it should not engage at all with the a/c switched off. Why would it always be engaged? Faulty switch? Stuck Clutch mechanism? any other ideas? It's an '87
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 07-31-2016, 09:58 AM
Pauld_94S2's Avatar
Unplug the wire going to the compressor clutch and see if that stops its rotation.
If not, then you have a bad/frozen clutch bearing.
Old 07-31-2016, 10:40 AM
kuehl's Avatar
.... you'd have a stuck front clutch hub.
The bearing is in the pulley.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 07-31-2016, 01:56 PM
good idea, thx guys
1989 S2
1988 S
1987 944 n/a (sold)
Old 07-31-2016, 02:37 PM
OK, i did that. the pulleys are still turning. After spaying it with pb blaster and tapping it with a hammer, i was able to turn the inner pulley by hand but it had a good amount of friction still. What next?
1989 S2
1988 S
1987 944 n/a (sold)
Old 08-01-2016, 06:17 PM
