removing the valve cover on 944
I've just noticed that i have a little oil dripping on the exhaust manifold down pipe, where it levels out.
Is this typical? And how easy is it to take the valve cover off and check the state of the gasket? Or is there another place which could leak oil at that rear section of the block?
thanks for your help
MJ in Beirut
Old 01-25-2016, 12:05 AM
M. Murphy's Avatar
I can't speak from experience but I do know it's much more involved than most cars because you are removing the cam carrier and the lifters as an assembly. Thankfully my 83 is leaking no oil in this area. Take a look at Clarks Garage site.
Old 01-25-2016, 03:32 AM
It may only be a loose bolt or two. Especially the lower (exhaust side) row. Re-torque them and see if the leak stops. Also there are bolts inside that need to be tightened. They are accessed by removing the six round plugs along the intake side (above the Porsche script). That usually helped on mine.
Old 01-25-2016, 05:00 AM
There is also a small cap at the rear of the camshaft cover - and its not uncommon to have the gasket of this cap fail, with a typical result of oil dripping on the exhaust pipe. A bit tight to work back there, but very doable to remove this cap and replace its gasket.
Old 01-25-2016, 06:40 AM
Yep. I forgot about that OK-944. Check that too. Replacing the gasket on that should be easy to do if needed.
Old 01-25-2016, 06:42 AM
would you tighten the cam housing nuts (inside) when the engine is hot or cold?
Old 01-26-2016, 05:23 AM
I'd do it cold.. The torque specs for engine assembly are for cold assembly.
Old 01-26-2016, 08:51 AM
Always cold.
Old 01-26-2016, 12:17 PM
Enjoy Jurgens video on replacing the gasket
https://www.youtube.com/watch?v=XcOWZV7RK4I
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 01-26-2016, 07:57 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Um, not to be that guy, but 944's don't have valve covers, they have cam-boxes. just saying. You might need a new gasket, or perhaps a bolt is loose.
Old 01-27-2016, 09:22 AM
We understand that but go along with it anyway. LOL
Old 01-27-2016, 10:18 AM
Rod Schneider's Avatar
Unless it's a 944S 16 Valve, in which case it does have a separate valve cover...........
Rod Schneider
Ball Ground, GA
88 928S4, 87 Corvette,
88 Fiero GT, 16 Mustang EcoBoost
Old 01-28-2016, 07:25 AM
So leaking valve stem guides would require removal of all of the upper-end rotating gear?
Old 01-28-2016, 02:25 PM
Yes but leaking valve guides? The reason you might lose oil through the guides would be bad valve seals. But the only way to test to see if the guides are worn would be to pull the head. You can replace the valve seals while the head is still on the car but you have to be carefull not to allow the valve to fall out of the guide and into the cylinder. Bringing the particular cylinder your working on's piston to TDC would help prevent that. Having said that, if you're going replace the valve seals, you're already about 30-45 minutes away (removing the intake) from pulling the head anyway and doing basically a top end rebuild. A head gasket kit will have all the seals from the head gasket on up so......
Old 01-28-2016, 05:45 PM
Patrick
pfarah's Avatar
I had two loose bolts toward the rear cam cover; a simple re-torque cured the problem.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 01-28-2016, 05:56 PM
Yep.. Had the same thing happen on mine a time or two. The last time I had the cam tower off to replace the gasket (it blew out on the intake side a little bit), I thoroughly cleaned those bolt holes out with brake cleaner and use some thread sealant on those lower bolts. Not had a leak yet.. Well, there anyway.. LOL
Old 01-29-2016, 11:52 AM
Porsche Crest
The gent didn't specify, but a shot in the dark its an older 944, with the cambox configuration.
Old 02-01-2016, 09:06 AM
No doubt!! Just trying to cover all the possibilities.....
Rod Schneider
Ball Ground, GA
Old 02-02-2016, 07:22 AM
Send a message via AIM to Lapponia
Hi!
I had the same issue in my 1984/944 few years ago. Exhaust wetted with one ore two drops of oil on the header at nbr 4 cylinder (front). Smoking for couple minutes and was annoying until burned away. This happend every week until I discovered a very small leak between cam housing and cambelt housing. Remedy, a cotton rope sling around that area sucking the leaking oil until fully saturated and then changed to a new one. That rope will last at least a year between changing and diameter of rope is 8 mm.
Check oil saturation of the rope regularly or the issue will repeat itself.
Best regards
Lapponia
Old 02-02-2016, 07:52 AM
kaotik's Avatar
944 1991s2 oil leak question, another!!
Pelicans
New to 944
Got a 82000 km 1991, s2,
small oil leak in THE morning on engine number
Seems to be coming from THE front
Oil drips on exhaust manifold and smokes for 6 minutes
Smells kind of funky
Oil leak is so small that it does not leave
Any mark on THE ground
Whats the fix, retorcking first, then changing gasket, then the rope trick?
Which gasket Exactly, part #
Retorcking is THE easy fix i guess
Thoughts?
Que sera, sera (pas toujours)
Old 10-23-2016, 12:55 PM
