goingboeing737's Avatar
Fuel rail / Injectors
While playing under the hood I noticed my fuel rail was loose. Upon further inspection, I see that the rear bracket that bolts to the manifold is broken. This allows the whole fuel rail to move sideways about 1/2 inch. I fashioned a small "L" bracket and attached it through the bolt that was already there. It's better, but not perfect. Is this a problem? Big, Small or not really. All of the injectors seem to be seated properly.
I did notice however that the injector right by this bracket has a little more oil/dirt deposit than the other three, Related?
Will try the Haynes suggestion of disconecting each one while running to see if any are defective. Seems to be running OK.
James
Old 12-07-2002, 11:09 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Don't sweat it too bad, just make sure they're seated in good. If yer really concerned, go the an O-ring kit ('bout $6), get the little helmets for them ('bout $dunno)cuz you'll break em getting them off. Take em all out, clean the intake where they seat, swap orings, carefully clean underneath where orings go. put your injectors back in, with the plug facing the right way (don't forget a little clean ATF for the lubba lubba) and then press & wiggle the fuel rail on, then bolt it down. Make another, tighter bracket if you think needs be.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-08-2002, 12:41 AM
My bolthole for the front bracket is stripped. I have not had any noticable problems, concequently, I haven't had it repaired. No leaks, or problems seating the injectors.
Old 12-08-2002, 10:34 AM
