Is this correct?
Hello everyone,
You know that i am in the process of supercharging my 86 n/a. My original plan was to use the n/a computer and put a j&s safeguard system for knock sensing and timing control, a 5th injector and an intercooler. Well someone told me this about when i supercharge my car, please read this and tell me if this is correct and will work.. Thanks
"John, the 951 computers are programmed for the early 944 n/a cams, lower compression pistons, fuel system(fuel pump, injectors, fuel rail, regulator), and some boost. With the 951 computers, they'd sense how much boost was being created/used and adjust the mixture correctly, even incorporating a knock sensor. Probably the cheapest and easiest way to
do you supercharging project."
This doesnt sound correct to me. Anyone? Thanks alot
John
Old 12-10-2002, 07:51 PM
Scott R's Avatar
Yes it does. That it why standalone engine management is a must for supercharged applications.
I used an in-dash air fuel meter by Lindsey Racing, and with the original NA computer the system took constant tweaking to keep it in check.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-10-2002, 09:15 PM
So you think it would actually be cheaper to use the 951 computers instead of a j&s safeguard system? Would i need the turbo injectors, regulators and rail then? Would i even need the 5th injector then? Thanks
John
PS- wouldnt this be very hard to wire up the 951 computer in place of the 944 computer especially since there are 2 instead of one?
Old 12-11-2002, 12:08 PM
Scott R's Avatar
No I meant you should investigate stand alone from another company. It was a pain in the but trying to integrate the NA electronics into the supercharger kit.
BTW I don't think you could run the 951 computer without the wiring harnesse, and some extra sensors.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-11-2002, 12:39 PM
