How much play in torque-tube bearings is too much?
So I'm doing clutch on my 951 and found that PO had installed an early 944na torque-tube... hmmm...
After I slid the TT back out of the clutch, I can spin the drive-shaft by hand and it continues to spin for a while. Rocking the drive-shaft up & down, I can feel some radial-play relative to the outside torque-tube. Looking in, I don't see any movement between the drive-shaft and the bearing's inner-race, so I think the sleeve is OK. Is this radial-play normal? How much is allowed? Or should there be no play? |
I think the right amount of play is zero. I would recommend to replace them. Its a lot easier than you think. The tricky part for me was riveting the bearing holder.
Tape measure, PVC pipe, dish washing liquid for lube a hammer and a couple of hours you are done. The original bearing bushings are reusable it removed carefully. Sent from my iPhone using Tapatalk
Never give up |
Yeah, i thought that even with larger C4 or C5 clearance, there shouldn't be any play. I might as well replace them while I've got it out.
Time to replace... You will be surprised by how much grease has migrated out from the bearings.
Good luck, George Beuselinck |
These videos ought to help out a few people...
https://www.youtube.com/watch?v=wHT1A8wJdfQ https://www.youtube.com/watch?v=J-j2Y0rqz3E Last edited by dgcantrell; 03-20-2016 at 08:22 AM.. |
I assume there's no way to extract the torque-tube without dropping the torsion-bar carrier?
Patrick
I heavily documented my TT rebuild a couple years ago. Not a difficult job but definitely time consuming. You have to modify the rivets to make them fit and I installed three each way.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
That Guy
Taking the torque tube out is one ****ty job, even with the car on a lift. The torsion bar assembly has to be dropped about 8 inches in order to slide the torque tube out. This is a do it once, do it right job. I decided to go with the SuperBearings made by Constantine on Rennlist. It was not cheap, but ill sell the car before i take the torque tube out again
.http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/547764-those-who-have-replaced-torque-tube.html
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
I've been hoarding a set of bearings for years now, dreading this job. Now that I have a worn out throwout bearing, I might as well do it all. Thanks guys.
