-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Dash lights fuse keeps blowing (http://forums.pelicanparts.com/showthread.php?t=907046)
rex LT 03-21-2016 01:54 PM
Dash gauge lights fuse keeps blowing out in my 1984 944.
The dash lights up with a new fuse, once the car is started, blows out within a few seconds.
What troubleshooting would I perform to diagnose this issue?
Thanks in advance
Jfrahm 03-21-2016 01:55 PM
Check the tail lights circuit also.
rex LT 03-21-2016 01:58 PM
could you please explain more
sausagehacker 03-21-2016 02:03 PM
IIRC there are a couple things on that circuit, including the gauges on the center console and maybe the cigarette lighter. Check the wiring diagram to be sure.
pfarah 03-21-2016 05:46 PM
Rex,
Have you always had this problem or is it a recent issue?
rex LT 03-21-2016 07:04 PM
Originally Posted by pfarah (Post 9047371)
Rex,
I've had the problem for about 4 months. Before then, in my previous two years of ownership the lights were good.
Jfrahm 03-22-2016 06:08 AM
If you have a decent ammeter see how much current the circuit is drawing. A small DMM might not be big enough.
Usually the tail lights circuit is connected to the dash lights so the driver knows if their tail lights are out. Look at your fuse diagram for related fuses and pull anything for the rear lighting, then see if the instrument lights start working, that will narrow things down. A bad bulb socket out back somewhere like the licence plate lights would be suspect to me. Any dodgy rewiring done back there should be looked at.
Ash tray and glove box lights are likely connected, lighter socket likely is not. Aftermarket stereo wiring should also be considered. Miswiring the lighting circuit to the head unit could cause this. Pull the harness to the head unit.
guru944 03-22-2016 06:59 AM
Rex Lt;
Does this happen also without starting vehicle and power + accessories is "on"
Reverse current and Ground loop is defiantly present.
Is vehicle store inside or outdoors?
If outside, rain may have grounded a printed circuit board or relay in fuse box; recommend start there...
keep us posted.
r
rex LT 03-22-2016 11:45 AM
Originally Posted by guru944 (Post 9047983)
Rex Lt;
keep us posted.
r
vehicle is stored outside. The lights work fine before the vehicle is started, once started, within a couple seconds the fuse blows
Shifter 03-22-2016 02:46 PM
I had a similar issue on a 968, and it was the dash light dimmer rheostat. Not certain if the early cars can have the same problem.
