-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Charging problem (http://forums.pelicanparts.com/showthread.php?t=91773)
NickZaimis 12-22-2002 07:02 AM
Charging problem
Hi Guys..
Recntly the car after being driven for while starts to slow down on charging.
It will not die ..but it will not start the next morning.
I replace the battery with a new one....same
Took the Alt to a shop and it check out OK.
So and the starter check Ok.
I replace the Voltage regulator.
Alt belt is tied and fairly new.
Is it anything alls there.
Anyone of you may have some idea or another componet to check?
Thank you
Cebu 12-22-2002 09:05 AM
Based on what you listed in your post...I suggest that you change the Battery Cables. They corrode internally and causes problems with current flow,
NickZaimis 12-22-2002 02:26 PM
Well....I quess you right...even i thought about it ....i didn't check them ....just shake'm up little.
I let you know...Thank's
