Can't get in...
My handles on the outside of the door don't really work well at all anymore. The inside is still real good. When u pull in the button it doesn't release the door mechanism. I have the door panel off and am not sure what I need to look for.
Is there something that I can just fix or do I need a whole new door mechanism? |
I had the same problem.
There is a little adjustment you can do from the plastic clip inside but it will not last. Eventually it will brake if is not all ready broken. You need to replace the handle mechanism . I think i had to pay about $ 50.00 each part. I install them my self.. |
| All times are GMT -8. The time now is 11:33 AM. |
