Alexb944's Avatar
Lucky guy
well Im having great luck with this car..
picked up my 85b 944 from the shop yesterday and drove it home
drove amazingly!
Drove it to work and drove out to west knoxville that morning as i am the carbuyer for Pullapart in knoxville.. parked at the car lot and noticed my temp guage creep up a tad bit.
and this smart guy decided to see if my fan would kick on at the 3/4 mark.. creeped all the way to a hair away from the 3/4 mark and POP! the temp fluttered up once and dropped...
NO steam no crazy idle, just nothing..
opened my door and noticed a huge puddle of coolant everywhere, popped my hood(engine off) and noticed a steady stream coming from above my timing belt cover and under the WP.. not from the hose or anything..
im guessing the water pump went out?(less then 15k miles) maybe just the gasket?? would it be better just to replace everything, as in timing belt/balance belt, water pump thermostat, hoses? also are they any cooling system flushes that are safe for the 944? Im having the best of luck with this car..
Old 07-16-2016, 06:54 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Sounds like time to replace the WP and as always with these cars, take advantage of "while you're In There" to do the belts, Rollers (if they continue to run when spun by hand). Belts should be changed about 30 to 40 thousand miles and/or 4 to 5 years. WP every other set of belts.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-16-2016, 08:49 AM
Yep. Waterpump is leaking. If you can't tell where it's coming from, it's probably the pulley shaft.... Where did you get the pump? Take it off and throw it at'em.
Old 07-16-2016, 09:24 AM
Alexb944's Avatar
the fella i bought it from was kinda anal about the car, he had paperwork from the moment he bought it and i still have all paperwork from him.. ive had the car for two months and put a total of 500 miles on it.
Old 07-16-2016, 09:43 AM
see if you can tell if it is the gasket or the shaft seal. pull the upper cover and hook up a pressure tester. a bad shaft seal will sling coolant inside the pulley.
don't rule out the exchanger housing. running a pressure test is the easiest way to tell.
Old 07-16-2016, 10:32 AM
