1888 924s sunroof problem
I have the late model sunroof motor on my car. Just in front of the sunroof motor is a small barrel looking thing that holds the tubes together that the cable runs through. The thingies that hold the barrel to the tubes are missing. When I turn on the motor to raise the roof, the cable pushes out between the 2 tubes and ties itself into a knot. Anyone know where I can get these parts or know of another fix. New parts are way to expensive. Thanks.
Old 07-05-2016, 01:58 PM
Auto Atlanta has a lot that they were tearing down. Also try classifieds here. Several being parted. 944 and 924 are the same
Old 07-07-2016, 06:35 PM
mhariush's Avatar
got a photo of the parts you need? I have some late and early cars that are getting parted out.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 07-07-2016, 06:53 PM
Here is the part I need
Old 07-11-2016, 10:37 PM
This is the part I need. Does anyone have one they will sell to me?
Old 07-12-2016, 07:16 PM
In the Fires of Hell.....
kdjones2000's Avatar
I just epoxied mine when the same issue happened. It's worked fine for the past 15 years.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-12-2016, 08:27 PM
Bump
Old 07-14-2016, 07:07 PM
Well the part number is 94456404800 which will probably help your search. The "barrel" and the tube that goes towards the motor are sold as one part. I'm not sure if they're ever supposed to come apart.
It is available from our host for $109.25. If that doesn't float your boat you can post a want to buy ad in the classifieds here or start calling the various dismantlers. Alternatively you could do as has been previously suggested and epoxy it.
Old 07-15-2016, 02:53 PM
