Hey guys! I have a hesitation under hard acceleration and with inspection I found a pretty loud humming on the fuel pump side of gas tank. Car stutters a little when idling sometimes too!
Is there a way to test the f. pump without just replacing it? Any suggestions? Thanks 86 951 Zermatt silver |
Sounds like your fuel pump is going out.
If you have a Haynes manual, it details how to check fuel pump operation without removing it. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Clogged fuel filter?
Could this problem be related to a really clogged fuel filter? That would make the fuel pump work quite hard, and would cause hesitation and such. It would also probably wear out the fuel pump after a while.
I am blessed/cursed with these cars: BMW 318iS 1991 BMW 325iS 1988 Volvo 740 Turbo Wagon 1992 Quote of the week: "This chemical is known to cause Birth Defects in California." Poor Californians, they are always getting the short end of it, and now this? |
