bumpy when driving, shakes alot
i jacked up my car and wiggled the wheel back and forth and there is barely any play in it. I figured it was worn tierods. When i go over bumps, it makes my car shake alot, and my steering wheel shake and sometimes turn. Also while driving along and i go over even small bumps and dips i can feel on my feet and hear kind of a clunking sounds, everytime i hit dips or my suspension "does" work, it clicks or clunks... My shocks seem stiff, maybe to stiff, im not sure what brand they are, maybe i just need some properly working new shocks, im not sure, any help appreciated, thanks
Old 01-03-2003, 11:19 PM
SoCal Driver's Avatar
You have to stay off the back packing trails!!
Scares the crap out of the tourists!!!
Yes, it's most likely all of the front suspension goodies; ball joints, tie rods, shocks, a-arm bushings and top strut bearings. Also the steering link. That's the u-joint shaft between the steering column and the steering rack. Don't forget the sway bar bushings too.
Seen a web site where you can get nylon replacement bushings for the aluminum front arms for $75 a set.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-04-2003, 12:20 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Could be a warped wheel. When wheels aren't perfectly round anymore, you will get shakes at certain speeds.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-04-2003, 12:57 PM
justin's Avatar
Does anybody make a kit to rebuild or replace the little u-joint in the steering shaft?
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 01-04-2003, 11:25 PM
Mine went because brake fluid leaked on it dissolving the grease in the steering u-joint (previous owner). Bought a used one from PartsHeaven for $25. P dealer wanted 225 bucks for a new one.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-05-2003, 07:29 AM
