Cold Air Intake Parts
For those that have changed to either a K&N or other cone filter, where did you buy the pipe that goes between the MAF and the cone filter. I have seen a few in stainless steel and some fiber glass. Thank you.
Don't.
K&N garbage... |
Stock intake is best!
1984 Porsche 944 NA |
James Chimney
Why do people waste their money on this crap? The stock air box with a K&N filter installed has more surface area therefore more airflow. Not to mention unless they lose the cold-air aspect of the intake. Even using the K&N ducting and housing shown above really does nothing to help performance at all.. The stock air box has a velocity stack inside to help smooth and direct the airflow from inside the box as it hits the AFM. This cone shaped air filters are nothing more than a gimmick.
87 944N/A since 1992 87 944S - Near Future Engine Project Car 88 944S - Current Project 84 928S - Restoration Project |
it is indeed largely about surface area. you must have AT LEAST as much surface area as stock.
that being said, COLD AIR INTAKES WORK if designed properly. K&N is a great filter. properly oiled, cleaned, and maintained, it does an outstanding job. ignored, over-oiled or dirty, not so much, but then neither does a paper filter. for a cold air intake to work, it must have a large filter, a cold location with good air access, and the connecting tube must not be subjected to heat, nor have a lot of bends in it, and it must be no smaller than the entry to the engine. the one above will not work well. the hose is kinked, and the ridges create resistance. the housing is too small, as is the filter inside it. at a bare minimum, that setup should be reversed, with the filter on the outside, and the hose between it and the intake point. serviceability may become an issue at that point though, as well as water entry |
