Ferrariguyma's Avatar
Send a message via AIM to Ferrariguyma
New owner Pop up headlights driving mechanic nuts
I have a 1984 944 NA.
I was not blessed with any mechanical skills, so I brought it to my trusted mechanic to have him address a few maintenance items and on my list for him was the pop up headlights. They go up perfectly, they only go down if I get out of the car and give them a slight tap.
He has lubed every point, tested the motor (clearly it works because the move one way)
Any ideas?
Thanks in advance!
Andrew
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed
Old 01-13-2017, 04:54 AM
This is usually the rotary contactor that lives in the headlight motor assembly, it gets worn and cruddy and may not make the right connections for proper headlight operation. Poking the manual knob moves the contactor to a clean spot.
It could also be the relay or switch I suppose. Be careful if you monkey with them as the linkage can operate unexpectedly and crunch fingers.
The easiest thing is to put in a new/used headlight motor as you may not want to pay labor for troubleshooting and testing.
-Joel.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 01-13-2017, 08:39 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
My headlights were going up and down when I closed them. I replaced the relay and it fixed it. Do the easy stuff first.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-13-2017, 09:31 AM
Thanks all good advice
Much appreciated!
Old 01-13-2017, 11:02 AM
Also check the plastic surrounds that go around the bulbs. Mine were loose and would move around. When the headlights were going down they would catch on the frame underneath. Rebolted in and no problems. Good luck.
Old 01-13-2017, 08:06 PM
Bradical's Avatar
Yup, similar experience here. It ended up being that my wiper pump fell loose and was interrupting the closing of the lights. Even simpler fix.
PCA - Florida Citrus Region
Old 01-14-2017, 06:48 PM
