-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Can we catch this gremlin? (http://forums.pelicanparts.com/showthread.php?t=94236)
interglossa 01-14-2003 03:09 PM
Ok, no the post isn't about whether or not a 944 can beat a gremlin... because, well, nevermind.
I've had somewhat of a strange occurance ever since i replaced my turn signal relay. I'll turn on my indicator and the "fasten belts" light in my center console turns on and blinks dimly, just as fast as the turn signal. I'm wondering if maybe i installed the wrong relay... i believe the stock relay was an old metal relay and i replaced it with a newer style. It fit and all the connectors were labeled the same.
Anyone had this happen or should i just sacrifice this whole thing to the god of quirky 944 electronics?
Roger Hall 01-14-2003 04:16 PM
Did you double check and make sure that you pluged it into the right connectors? Somehow the sealt belt light is connected to the turn signal circuit, weird...
