That time of the year again...SoCal 944 service
Offering my time/services again for the southern CA 944 community...
Been traveling CA since 2008 working on 944's, from San Diego to Berkeley, west LA to Palm Springs. I am the one who LART calls to fix his 944s (at least the ones that get a stay on their execution ). I can come to you, or you can bring your car to my garage in Rancho Cucamonga for work to be done. Anything and everything is doable, pending scheduling. Most common work I get called for is timing belts, water pumps, and head gasket replacements. Timing/balance belt cost (includes parts): 944 8-valve $600 (add $50 for 944T) 944 16-valve $700 Full head gasket replacement (includes parts + machining) 944 8-valve $1500 (add $150 for 944T) 944 16-valve $1800 Water pump + front seals add $200 to timing belt/HG cost - I use ZIMS rebuilt water pumps exclusively. Other jobs...please PM me! |
Bumping this up as weather gets better.
Spring is almost here, make sure your 944 is up to date on maintenance so you can drive it care-free... |
