Radio install
Ok who has installed a new radio, what kind and what did you need and where did you get it, I am looking for a Blue Tooth unit (for music on my I-phone to play, maybe phone calls and texts.) did you upgrade the antenna?
No need to upgrade the antenna on the later cars. They are boosted so be sure to connect the black wire to the booster located behind the glove box to the, usually, blue remote power lead from the receiver. I had a Pioneer CD player/controller in mine for years before I put it in my 914. It went with the 914 about 5 years ago. I had put the Blaupunkt Charleston back in it. But any decent car receiver will work pretty well. Some wiring adaption will be necessary but it's pretty simple at it is.
Hi James- you can check out the link below to see what will work for your car.
https://www.crutchfield.com/car/carselector.aspx?lp=%2fCar%2foutfitmycar%2fmycar.a spx |
| All times are GMT -8. The time now is 04:07 PM. |
