Coeur d'Alene, Idaho
What bit needed for those flywheel bolts?
I have a torx 55 that fits it, but is there a bit I could get that has all the points on it? Size?
Thanks.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 08-13-2017, 03:33 PM
You need a 12mm XZN drive tool, and a high quality one too. I personally have Stahlwille and Hazet. They both have a slight interference fit. Others I've used have some clearance built it and are notorious for stripping.
Old 08-13-2017, 04:13 PM
GearWrench 80572, has every 12 point triple square bit you need.
Good luck, George Beuselinck
Old 08-14-2017, 06:14 AM
In the Fires of Hell.....
kdjones2000's Avatar
Pep Boys should have a set of cheap 12 point internal bits that you can get quickly.
Not the best quality, but may work for you.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 08-14-2017, 07:40 AM
you can get a set of 4 different sizes "triple square/cheese head/xzn" for like $8 at your auto store, they work fine, just make sure you seat the bit fully in the bolt head or youll be back on here complaining how those bolt heads strip so easily...
Old 08-14-2017, 09:15 AM
