Weltmeister 200# lowers too much
Ok, so I've just got Weltmeister 200# lowering springs on my M474 Koni front struts.
Problem is that front is now way too low for my preference. I have searched the forum and some comments about these springs to not lower car at all. Well, not for me. I know the WM springs lower approx 1.25" (33mm) but I was under the impression that the M474 standard spring was already slightly lower than stock (396 vs. 407mm free length) and I would therefore only see a "mild" lowering. Besides, the stiffer new spring would mean less compression than the stock 125#. Has anyone tried VM 200# with M474 Koni's? What results did you see? PS: Car is 87 951. Thanks /Peter ![]() ![]()
if you are just after stiffer springs you can get a spacer to bring it back up to stock height. i have these springs and the spacers on my car.
i imagine you could shave/grind off a substantial amount of material to get the desired ride height. |
Yes, I've seen these spacers but have been a bit hesitant as it seems like a non-standard solution. I don't think I would pass check at road-safety inspection in my home country :-)
Do the spacers fit under / over the spring or between the coils? |
there is less un-sprung weight with the tighter coils on top.
the 1" spacer from weltmeister is part number P915725 http://www.automotion .com/weltmeister-coil-spring-spacers-for-porsche.html remove the white space it is typical on a Mercedes to change spring spacers with engine weight. i doubt you will fail inspection for spacers made by the spring company. Last edited by thomasryan; 08-14-2017 at 05:53 PM.. |
Thanks V2 and Thomas.
I'll go ahead and order the spacers. I am just curious as to why I am getting such a different results with the same springs? The old springs dyno'ed at 107 lbs/in, so the new ones should compress far less. I just wonder if the M474 lowers the car not by spring but through strut design. I assume the spacers are installed at the top to further lower the unsprung weight? |
I would put them in the lower perch but contacting weltmeister would be definitive.
I used a 5mm caster adjuster washer and 3mm bmw 5 series rear spring spacers to shim my front CS springs. |
Ordinarily, you would use threaded adjustable cups on the strut to correct for spring height.
What is the difference in height between the springs you took off the replacements? |
