-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Brake sensors! (http://forums.pelicanparts.com/showthread.php?t=967232)
944 S2 08-20-2017 04:39 PM
Brake sensors!
Ok so I did my brakes a little bit ago. New rotors and pads. Right away I noticed my brake sensor light on in the dash. So I thought I simply didn't plug it in all the way. Now I'm finally getting to it again. I checked the continuity on the sensor and it is an closed circuit! I expected an open circuit! I'm I going crazy here. Please teach me!http://forums.pelicanparts.com/uploa...1503272237.JPG
thomasryan 08-20-2017 04:53 PM
Is the brass clip square in the pad backing plate? It good practice to replace the sensors but I don't even though they are so cheap.
Does your car come with the clip that holds the red wire?
944 S2 08-20-2017 05:27 PM
These are new sensors. The question is are they a closed circuit to begin with. Then I assume the wear breaks the circuit and the light comes on?
Bukowski 08-20-2017 06:02 PM
I had the light on forever, trying all sorts of nonsense to solve it.
Finally ponied up for a new brake wear sensor _wire_harness_ - like magic. Expensive magic.
Never managed to make a DIY harness... the wires corrode like hell underneath and way down the wires.
Bukowski 08-20-2017 06:04 PM
Check the ground for the harness too - maybe bumped?
kevingross 08-20-2017 06:28 PM
The sensors are closed circuit when new, and the circuit opens when they are worn to indicate a need for pad replacement.
944 S2 08-20-2017 08:27 PM
Minor update.
Cleaned all four grounds.
Checked the new sensors for conductivity.
Still the light is on! Suggestions
Bukowski 08-21-2017 02:54 AM
There are eight grounds - one on either end of the brake wear sensor wire harnesses.
944 S2 08-21-2017 05:06 PM
Starting to think maybe the wire harness has gotten damaged!
thomasryan 08-21-2017 06:37 PM
the paint on your rotor might be outside the box but no ground there.
did you look in the round plug for corrosion? the cylinder cover usually wont clip shut if the plug isn't bottomed. you should have a ground on the rear at the bottom of the backing plate and I do believe it is on the strut housing up front.
off brand sensors?
