Wolf1's Avatar
0-60 in a 931, A little sad.
Just thought I would share my baseline 0-60 times in totally stock form before I begin with an intercooler and more boost.
1. 8.9 sec........ too much wheel spin.
2. 9.1 sec........ not enough wheel spin.
3. 8.7 sec........ about right on launch.
45 degree outside temp.
4700 feet elevation.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 02-01-2003, 04:55 PM
Ornery Bastard
Those are about a second off of what a stock 931 ought to be doing. You sure that the car is running 100% right? The 924S which has a basically identical power to weight ratio has been clocked at a high-seven-second 0-60. Not sure about elevation though. Still, the 931 should do better at altitude because of the turbo overcoming the lower atmospheric pressure.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 02-01-2003, 08:25 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
931s, 924S, and early 944s should be posting very similar accelleration times (7.4-7.9ish) Perhaps your engine is just tired? it is an old car
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-01-2003, 08:33 PM
Wolf1's Avatar
Everything we test around here seems to be about a second slower than advertised times.
99 Explorer 4.0 sohc 5 speed auto 10.8 sec
01 Durango 5.9 4 speed auto 9.9 sec
99 Mustang gt 4.6 5speed manual 7.1
95 Trans-am LT1 ws6 6speed manual 7.1
83 F150 4x4 modified EFI 460 C-6 auto 6.6 - 7.3 depending on traction.
Real world test conditions seem to vary alot, traction is a big issue on some of these, 931 included.
The engine may be a little tired, but it doesn't show it. It will be interesting to see how the mods change it.
75 914 - Undecided.
Old 02-01-2003, 09:20 PM
Ornery Bastard
That's altitude. N/A engines lose power because of the thinner air effectively reducing compression. If the turbo has a wastegate, it ought to compensate for altitude and make full power up until the turbo is maxed-out.
Aaron
Old 02-01-2003, 10:44 PM
Writer/Teacher
CJFusco's Avatar
Or it might be that the guys at ROAD & TRACK are experts and know how to launch a car to get the best accelleration time results
Old 02-02-2003, 09:19 AM
I think when the manufacturers test 0-60 times, they crash shift the gears - ie they doin't use the clutch. This saves 0.5s or so on each gear change. Your real life 0-60 times will be slower on a manual box as I'd assume you want the car to last and change gear normally.
Doesn't apply to automatics of course
Mark
Old 02-02-2003, 10:06 AM
Yan Yan is offline
Mark_944S2: I don't think so. The 6.0-6.5 seconds 0-60 mph acceleration made by manufacturers or R&T and C&D with the 1st gen 951 is easily achievable even when considering the gears changes. Some people even ran below 6.0 seconds in stock form.
Wolf1: What is your launching method? With your turboed car, you should make a 3000+ rpm clutch slip in order to match the magazines specs. That's not the best thing to do with a Porscha.
.: My turboed 944 - Videos | Pictures | Specs [...] :.
One ride and you'll understand why most rocket scientists are german.
Old 02-02-2003, 10:14 AM
Ornery Bastard
Yan's right, the 924S was listed as having an 8.3 second 0-60 from the factory, but owners have listed 7.5-7.6 second times without crashing the gearbox. In my experience, R&T's performance figures are easily attainable without abusing the machinery. R&T has at times outlined their testing procedure and they always emphasize that they do not go all-out to shave those last couple tenths of a second, but rather they try to make sure that their methods are repeatable by owners without causing undue damage to the cars.
Aaron
Old 02-02-2003, 11:32 AM
Writer/Teacher
CJFusco's Avatar
Yeah, the previous owner told me he got 0-60 in 7.6 in my 83 944, but the average road test is probably closer to 8.0... some even got as slow as 8.4... although I have seen them as quick as 7.4 in some magazines... and yes, I do mean US spec cars.
Old 02-02-2003, 01:59 PM
Porsche are known in the U.K motoring press as being pretty conservative with acceleration times. i.e The s2 official 0-62.5(0-100 km/h) figure is 6.9 seconds,however Autocar '86 acheived it in 6 dead.
Just my 2p worth.
John
1985 Porsche 944 Pastel beige. 88k sold
1992 Porsche 944S2. Guards Red. 95k sold
1990 Porsche 964C2 Baltic Blue. Not standard.
1958 Austin Healey 'frogeye' Sprite '58 cherry red 70k
Old 02-02-2003, 03:17 PM
Thats '88 not 86.
John
Old 02-02-2003, 03:19 PM
Wolf1's Avatar
Launching between 3500 & 4000 rpm with clutch slipping a little and tires slipping a little as well. Any higher launch rpm produces too much tire spin, any lower engine bogs down a little. I may not be producing full boost, I noticed today that the O-ring seal on the turbo discharge is a little worn and loose and may be leaking some pressure. I will fix a few items and install a boost gauge and retest before any mods. The intercooler install looks like it wont be as difficult as I originally thought, I removed the windshield washer reservoir today which opens up a large passageway to the front of the car, remounted oil cooler back about an inch or so and now two 2.25 tubes will fit through there. I will replace the washer bottle with a smaller one mounted up near the battery.
75 914 - Undecided.
Old 02-02-2003, 06:26 PM
Wolf1,
Where in I.F. do you live? I am originally from Ammon and go to visit my family a lot. I have a 968 coupe and know ZERO others with a Porsche.
-Mike
Old 02-05-2003, 08:38 PM
Wolf1's Avatar
Mcnett, I'm about 10 miles north of I.F. between Ucon and Rigby. There are a few Porsches running around in the summer. Boxsters, 911's, 914's and a really sharp 911 RUF turbo in guards red.
75 914 - Undecided.
Old 02-05-2003, 09:13 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I think your watch is broken.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 02-06-2003, 01:34 AM
