Wiper Motor - Bench Test?
Trying to determine which is not working...the wiper motor, or the wiper switch. The car's an '83, and the wiper motor and switch were replaced about 4 years ago. When they last worked, there was a irrating grinding like noise, that I assumed meant I'd need to lubricate the wiper arms.
Now the wipers will not work in any position. The motor seems to be locked up, I can't turn the knurled drive shaft, either with a pair of plyers or with it attached to the wiper arms. With a multi-meter, I checked the plug from the firewall to the motor, and found a couple of different pin combinations that are activated by the switch, but after reviewing the wiring diagram, I'm still having a hard time determinining what pins should be active for the different switch positions. Anyone have a way to bench test the motor, and/or some ideas on the pin combination that should be active for the different switch positions. Thanks
yep, jumpercables to your 12v batt. I tore my wiper motor down and cleaned it up. got anotherr 6mo out of 'er. Course, in california I prolly used em twice. New motor: $ungodly$!
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
I have a good working motor I might part with.
1983 944 - Project Time! 1986 944T (Stolen) 1987 944 N/A (Sold) 1984 944 N/A (Sold) 1986 944 N/A (Sold) |
I have a complete motor and arms i'll sell you, Also have wiper arms if needed, 35 bucks plus shipping, email me if your interested
Roastin944turbo@yahoo.com Thanks John |
XJOSHX - can you turn the knurled shaft on your motor? Mine seems to be frozen up.
Todwic - Thanks...but what two terminals would you connect on the motor to the battery? I tried using a test wire from the battery to the red and green connections on the motor...but I didn't get any spritzen sparken...red to positive, green to negative? Roastin944 - Thanks...If mine is really dead, I'll be contacting you shortly. Thanks guys
Knurled shaft is attached to a worm gear. Kind of hard to turn; working against the gear design. Turning the motor shaft is the only way these are supposed to work.
Bob S. former owner of a 1984 silver 944 |
