Head gasket
Well, after all I've done to get this 924S running, it seems I have a leaking head gasket..in a perfect world I would replace it, but it's not feasible at this time. I don't have coolant in my oil or oil in my coolant and it isn't overheating nor is there any gas bubbling in my coolant reservoir. I've pulled plugs and #1&#4 are definitely "steam cleaned". My question is, would there be a head gasket sealant that might possibly work? Any input would be appreciated
Old 10-25-2017, 05:21 PM
Did you run a coolant pressure test to see if it holds pressure? Could it be leaking injectors instead?
Old 10-26-2017, 03:05 AM
Injectors have new o-rings and hats. I did test them after cleaning and backflushing. I do plan on testing cylinder compression and I'll also test coolant pressure. Thanks for the suggestion.
Old 10-26-2017, 03:26 AM
Coeur d'Alene, Idaho
Where are you? On other forums I'm a member of, people put their location in their signature and when faced with a task on the edge of their ability other members in the area can post offers to help. If you were in my area, I'd lend a hand if I had the time. A head gasket is one of those jobs people consider intimidating until they've done one. Then they say "Huh, that wasn't so bad." It's more a matter of staying organized than any particularly challenging wrenching.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 10-26-2017, 11:14 PM
I pulled fuel and manifold components to replace o-rings in the AOS a few weeks ago. I'm not totally convinced its a head gasket issue. I had water droplets on #1 and #4 plugs, but they also were carboned up, so maybe "steam cleaned" may not be a fitting description.Someone mentioned FPR and possible leaky injectors. Once I get coolant and cylinder pressure figures, I'll know more
Old 10-27-2017, 06:15 AM
