least common denominator
scottmandue's Avatar
Porsche Crest Trans bolts rusting/cleaning tranny?
Hey when I was checking out my gas leak (thanks to SoCal for the advice/free fix) I noticed had some grease caked on the transaxle (but no leak) and I was thinking I should get under there with some degreaser and clean it up. I also noted the bolt heads that point towards the rear of the car are rust color. I'm thinking aluminum case with steel bolts? is that right?
I always thought dissimilar metals was a no no.
Is it okay to spray engine degreaser on the tranny?
TIA
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-08-2003, 12:17 PM
Roger Hall's Avatar
Degreasers wont hurt aluminum
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-08-2003, 07:36 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Dunno, I saw a phone dial wheel cleaned by a degreaser, and it looked like a bronze color...
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 02-08-2003, 07:47 PM
Roger Hall's Avatar
I think the bronze discoloration was from a coating on the wheels.
Roger Hall
81 924 N/A
Old 02-08-2003, 09:02 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
I would assume that the degreaser wouldn't hurt anything. If it were me I wouldn't worry about it though, just plan on having to use a bit of WD-40 if you ever have to take it off.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 02-08-2003, 10:17 PM
Send a message via AIM to Trevor
Never use a degreaser on the rims, you can ruin the finish, but on the trans casing you should be fine.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 02-09-2003, 08:07 PM
SoCal Driver's Avatar
Re: Trans bolts rusting/cleaning tranny?
TIA
Think there might be a vent on the top of the trans. Have to check that.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-09-2003, 08:53 PM
AFJuvat's Avatar
Had good luck with the spray degreaser, followed up with a scrub brush and soapy water.
Don't think there is a vent per se up there, but at least one electrical connection, so I avoid the top of the tranny.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-10-2003, 02:41 AM
