-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   CV Joint Assembly Question (http://forums.pelicanparts.com/showthread.php?t=97608)
ky951 02-09-2003 07:38 PM
Hi. I’m in the process of replacing a torn CV boot and have run into a problem.
I used a puller to remove the joint from the axle and removed the cup washer along with it. My axle seems to be an aftermarket replacement and the cup washer has a ridged inside diameter that matches the spline on the end of the shaft. The joint/washer was a real pain to get off even with a puller. The problem is the washer that came with the new boot kit is too large (slides past the stop) and I don’t see a way to get the original back on without damaging the shaft splines. The CV joint itself also looks like it doesn’t want to go back on.
Any ideas?
todwic 02-09-2003 10:28 PM
You did take out the circlip first, aye?
ky951 02-10-2003 04:42 AM
Yes.
