n/a to S2
How hard is it to swap the S2 engine into the n/a? What all needs to be changed?
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
Check this out, it may anwswer some questions for you.
http://forums.pelicanparts.com/showthread.php?threadid=82509&highlight=S2+conversion
1984 - Porsche 944 1994 Grand Cherokee 6inch Lift, 33" TSL'S |
nice mod !
The short answer: it's hard.
There are lots of components that need lots of work, like the air intake. Also: you would want to upgrade your brakes to the 951 brakes (which the 944S2 has). There are other components and issues, but I don't remember them (Perhaps someone with more technical experience can further describe). In the past when this has come up, the general consensus was that it's probably more cost effective to sell an n/a and buy a complete 944S2. But if you're up for an engine swap, and enjoy that kind of stuff, and have some funds to spare, then the project IS doable. -Zoltan.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
I had planned on getting 993 brakes before I swap it in. I had also planned on upgrading my suspension to a real @$$ happy set-up, oversteer is my friend
Off hand I'm pretty sure the torque tube/clutch assy should work. To swap the engine you will need the complete engine (though accessories should be interchangable) with all sensors, the wiring harness, and the DME.
Other than that it should be pretty smooth except for the intake/exaust. It'd be wise to upgrade the brakes/suspension like Zoltan says. I think however that the 993 brakes would be overkill. Ahmet
Cheers! |
Brakes are cool! I would also like to go forced induction on it someday.
