speakers
hi all. just picked up a 86 951. it was missing the speakers. im looking for new speakers for the front and rear. what will fit? all the threads I found on here are older. and all the speakers people recommend are not available anymore. im not looking for the greatest sound. I want to use my original speaker covers in the doors too. any help would be greatly appreciated
The height of the center coax tweeter speaker may be too tall and prevents many of newer speakers from fitting with the original grills. However there are a few models out there that fit or can be modded to fit by removing a spacer under the coax tweeter.
Administrator
https://www.crutchfield.com/car/carselector.aspx?lp=%2fCar%2foutfitmycar%2fmycar.a spx |
944 S2
Here’s what I put in the fronts. Required some small mods however make the covers work.
![]() ![]() Pioneer TS-4675R Last edited by 944 S2; 12-06-2017 at 06:31 PM.. |
944S what did you use in the rears
Alpine SPS-406 will fit with the factory grill covers for the fronts.
RL: Dave951 dave951.blogspot.com |
Not in may car, or may grill covers may not be factory. What do factory grill covers look like?
2010 Cayenne GTS |
I've attached a photo of the standard grill. When I torn down the factory setup I remember there were these small plastic spacer/bosses between the speaker and the grill. Having them in place added a little extra gap between the two components which might have helped fitting them. For reference is was a late 87 951.
944 S2
I used Alpine SPS-410 Type S 4"2 way speakers in the rear. Seems fine to me. Good mid range punch from what was in there before.
2010 Cayenne GTS |
2010 Cayenne GTS |
West Central Ohio 45380
Here is a list of speakers that fit:
http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/963579-fs-speakers-head-units-blaupunkt-infinity-pioneer.html
www.plyhammersparts.com |
curtisr
I would install these but I have no idea what they're called or where to find them...
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold)
You may be able to remove the plastic trim from the top of the center cone and not need a spacer. There is also a screw thru the center cone that can be removed and a spacer removed to lower the speaker profile so spacer's are not needed.
88+ cars (before 968) that do not have ten-speaker have a taller speaker grill.
https://rennlist.com/forums/924-931-944-951-968-forum/571184-rear-speakers-install-pics-w-o-window-removal.html#post7632425 Conversely, someone has made a printable spacer. Not sure if it is for early or late door panels. https://www.thingiverse.com/thing:1132372 Last edited by FrenchToast; 12-13-2017 at 05:00 PM.. |
Thanks, I'll look at that.
2010 Cayenne GTS |
